Anyone point out where the rear end jacking point is on the rolla to lift both wheels same time,picture possibly
thanks.
Look for the towing point, where it connects to the chassis.
Don't know if it applies to all model but think its all 2002 on ones, if you look under the spare wheel well at its forwards most point, just before the rear beam you will see a wedge shape sticking down about 3 " or so, thats the  official central  jacking point according to the haynes manual
However with a typical diy trolley jack I find I have to put it on a couple of scaffold boards to gain enough height to get both wheels up
Whatever you do, do not rely on it, because as I have found as the jack goes up, it can move a little and drop of the jacking point and bash into the wheel well.
Once its up, you must put jacks  or axle stands under both rear side jacking points , indentifed by the little half moon cut outs.
If you don't have these supports, and the trolley jumps off the wedge to will have serious or fatal results !!
Thanks guys il have a look underneath,yeh no doubt I never get under the car without just the jack holding in place always make sure got spare wheel under the car and axle stands before heading underneath
