Slight clunk from 1st and 2nd if I let the clutch out quick
Neilll
I'm over the moon with my new 2010 XT-R 2.0 petrol. It runs like a dream, apart from if I let the clutch out to the biting point to quick there is a slight clunk, nothing major but its definitely there, sounds like the clutch or gear box area  quite central I think. Hope somebody has some advice as to what it could be, cheers
Hi Neil
Plus prop shaft bolts and universal yoke bearings.You can do this by gripping the prop shaft when nothing is running and see if there is any twist or click there when you turn it each way slightly
Del
