No engine management light
S1-crysis
Hi i have done a search on the forum and cant find anything also cant find anything online but basicly i have no engine management light shining up on my dash when turnin on my ignition i used to have one but its stopped appearing is there a fuse for the lifht or anything i havnt a clue what could be causing it thanx josh
does the toyota yaris use bulbs there or is it pcb also iforgot to put on the post my yaris is a 2004 plate
May be a simple as a blown bulb, remove surround from cluster unscrew 2/3 screws holding cluster in and couple of connectors going into the back of them, replace bulb with one beside it(if you dont know which one is eml on removal shine the cluster up to light and you should see the symbol) if thats not the case id go checking your fuses
Thanx i have just removed the cluster and had a look at the bulb and its deffonet blown any ideas where id find one and what bulb it is thanx josh
Toyota dealers will sell one. It is not a standard one.
Special order when I bought one.. Takes a couple of days.
