Help
Chuck04
okies so after speaking 2 kevin i finially worked out how to fit my lexus lights, there on now and i have working lights and breaks,
heres the problem, indicators were working but now there not, and the icon lights up on the dash ie indicator lights fogs etc that come on when u turn the lights on dont come up anymore...
kinds confused :( could i have blown a fuse or somin ???
this is guna sound dumb, but honestly, it happens, are u sure that the indicator light switches are secured in tight and properly?...
haha is that the thing 2 the right hand side of it at the top, with a funny rubber thing which touches the hood of the bonnet, well ive the alarms stopped but havnt diconnected them, think i may have ****** the electronics of the car up, ill drive it down 2 toyota and see if they can do anything recon thats the best thing 2 do???
remove the lamps and check the wires have not been crushed and split against the bodywork. if they have put some tape over the cuts (i did this) it will have blown the fuse aswell which is a red 10amp fuse under the bonnet
check those two areas first
