Hello again,
I've noticed a noise coming from after releasing the clutch pedal. It is a like a low frequency sqeak that last for about second. It only appears to occur when i change between 1st and 2nd gears and does not occure all the time. I also thougth it may be coming from the power steering as usually at low speeds is when I'm turning the wheel significantly and the cabin noise is not enough to drown out the squeak.
It could be many things, the clutch release bearing can make some noise as it ages.
Could be the clutch pedal pivots both inside the cabin and on the engine slave cylinder, just search the forum on squeaking clutch for how to cure .
