 I have a 93 Toyota Corolla with a manual transmission speedometer went out so I changed the dash cluster with a dash cluster from a junkyard car that the airbags had gone off in. It didn't solve the speedometer problem so I replaced the original  speedometer and now the SRS light for airbag light is still on and I can't reset it. There's nothing wrong with the airbag system again this is just because I put a dash cluster in from the car that the airbag had gone off in.
someone please give me the procedure for resetting the SRS system
Toyota tend to use the same systems on different model, within the same year/generation. So even if for a Camry, may work for Corolla
I did a quick search and found the following:-
http://repairpal.com/air-bag-light-679
http://www.automotiveforums.com/t470144-airbag_light_reset_procedure_.html
At worst if nothing works, you may need to go to an auto electrician, who may have legacy tools that can clear the SRS light.
