USB Port Not Working?
gswindale
Hi All,
I have recently purchased a 2nd hand 2013 plate Auris.
I have so far attempted to connect my old Creative Zen MP3 player by USB; a brand new USB stick and also my mobile phone to the USB port - in all occasions the USB option on the Touch & Go (or whatever it's called) system has not been enabled.
Is it likely that there is an issue with the USB port in the car itself; and would this be covered under any warranty if it requires fixing?
Many Thanks
Without knowing what country you're in (your profile provides only the most basic of information), members cannot say whether the car is still covered by a new car warranty, so will be unable to advise. If you bought the car from a dealer, go back and ask them to sort it.
the usb port connects into the rear of the head unit it may of come loose and need reseating
Also check drives are formatted correctly, need to be in FAT32 afaik, but this restricts file size.
Just an update after taking it in & them confirming it didn't work - they finally took it in today & discovered the port was not connected at all; so have had it reconnected & all is working fine now.
Back home & my Creative Zen MP3 player now works perfectly as far as I can tell.
just what i said its on a push in plug on the back of the head unit or sat nav unit
glad its sorted for you
