Engine Mount Failure
Kuneha
It appears my LH engine mount has split on one of its legs.
eBay doesn't have any replacement mounts nor can I find any website and I am reluctant to call Toyota, although it seems I have little choice.
Has anyone else suffered a split mount and do you think it's worth changing all 3?
Be worth having the others examined for wear/possible failure.
I think I'm likely to change all 3. They're all original so I doubt the others are fairing much better. They may not be split like the one I examined but I'm sure they're as soft as a sponge after 48k miles and 6-7 years of weather.
I'm worried slightly of the prices from Toyota. I'll post them out of interest once I give Toyota a reluctant call later today.
I called them. It is times like this that I regret buying this car.
The engine mount which is the vacuum operated mount is £199.
The gearbox mount near the Battery (this is what I'm replacing) is £123.
The dog mount or torque mount on the bottom is £90.
So to change all of these mounts one would be looking at over £400.
There are no aftermarket alternatives and no other 1KR-FE mounts from other cars will fit.
