rotating tires
monkeydave
if i rotate the tires will it mess up the tpms system on the 2016 yaris ? or will i need to push the button under the dash?
thanks guys
It won' affect the TPMS as it does not report a wheel position just that there is a pressure issue, one thing to consider though is to check if the tyres are directional as if they are they can only move front>back and not side>side
thanks for the help glad it is just pressure and not location
