Yaris 04 rear wiper motor needed - advice welcome
billythe fish
Hi. I need to replace my (removed) rear wiper motor. Part number is 85130 0D010. Its the French model. Am I limited to this part number or are there alternatives? huge thanks.
Just a thought. The french version has blades/arms available from Halfrauds, whereas the jap version ie T sport can only be got from Mr T at 4 times the cost. I understand that the motors are interchangeable. Check out online for cheap replacements. Cheers Colin.
thanks. Can anyone suggest anywhere online for anything that will fill the hole and shift the water? The Toyota ones are about 60% of the value of the entire car! thanks again
Replaced. I removed the fabric cover inside the tailgate. The wiper was removed from the spindle.The wire to the motor was unclipped and the 3 bolts removed. I opened up the old motor and the purple plastic gear wheel and gear worm were destroyed. It's a shame that they used plastic for these two parts in what's otherwise a nice unit. I bought a used motor and opened it up. It was good. I added grease and resealed it. Fitting it was a 5 minute job. All good. thanks for the help. The tricky bit was the removal of the old wiper blade from the motor spindle. It hindsight I might as well have just sawn it off!
