How to disable passenger airbag?
Conach
Is there a way to disable the passenger side airbag in a 2012 Prius Hatchback? I have searched the forums and google but can't find an answer. I want to do it to put my 2nd baby in the front seat as we cannot fit her and my first baby in the back as well.
There's a switch on the passenger side edge of the dashboard - if you open the door you'll see it. It's in the owner's manual, "Airbag manual on-off system (for Europe)".
So do you need to update your profile to include the Prius.
No, it's my father's car. We would be borrowing it for this particular trip.
  • 1 year later...
On 2/23/2017 at 3:34 PM, Conach said:
Is there a way to disable the passenger airbag in a 2008 Prius?
Tnx
2008 Prius - if not in the same place, then perhaps in the passenger glove box..... maybe
  • 8 months later...
Prius 2008 does not have nothing in either top/bottom glove box or on the side. There is however a sign that says that you shouldn’t put a rear facing child seat in the front passenger seat. This placard is visible when you open the front passenger door and on the passenger shade maker.
