Number plate light
Alex-avensis
     one of my number plate light bulbs has gone. I had a quick look but could not see any screws to undo, so how do I get access to the bulb? Just off to work now, will check back later tonight.
Very easy. Open tailgate, remove interior trim panel cover with flat blade tool, twist and remove bayonet bulb holder, pull and replace 501 - 5w wedge bulb. Job should take a couple of minutes. Done it a couple of times.
You should get yourself a Haynes manual. Most jobs are covered, but still ask on the forum and check my posts, as I have done most things like routine oil changes, most bulbs and self diagnostics - early phase 1, pre- vvti cars did not support OBD2 standard. There are other things I have done, like replacing the crankshaft pulley, wheel bearings exhaust, oxygen sensor, starter, ignition switch, brakes, speaker upgrade, basic remote key issues, fusible link, radiator, ABS control unit (easy job), I could go on. The car had regular cambelt changes, water pump, gearbox rebuilt. The current owner is enjoying the car right now.
