Auris no spare wheel
Slasher_uk
Is it possible to get the fittings for a spare wheel in the boot rather than the puncture repair kit which comes as standard.
The spare wheel kit including the spacesaver can be ordered from your Toyota dealer. Not sure if the kit will accommodate a standard wheel/tyre. A search of the Auris club should unearth the components and part numbers.
If you read the manual you will see that it can be configured to accommodate the repair kit, a spacesaver, or a full-size wheel - depending on the local market. I ordered a spacesaver to be fitted instead of the repair kit - it was a dealer-fitted item rather than the official factory-fitted one - it's a bit of a bodge, tilting the floor of the under-tray, but acceptable
