Oil check problem
john_tsax
Hello mates.Nice to find you.
I have a toyota yaris 1.0 1999 model with 1sz eingine.
I tried to check the oil level and i accidentally broke the oil dipstick.
I bought a used one but i dont think that is the same.Can anyone tell me the cm from a genuine dipstick.
I just changed the oil and it took 2.2 litres ( the manual says 3.2 with filter).
Hi John.
I don't have a Yaris so cannot give a direct answer. I do have a couple of ideas. One is the following site on Amazon that supply dipsticks:-
https://www.amazon.co.uk/Engine-Dipstick-Assembly-Replacement-15301-28030/dp/B00CFR73G0
Secondly, if you kept the broken dipstick, you can compared the new one against the old. That is what I did years ago when I had to replace a broken dipstick. The dipstick was a slightly different design, but were the same length from the top of the tube to the "MAX" and "MIN" marks. Above the top of the tube to the handle was slightly different, but that did not matter.
Hopefully you will get answer you want. :thumbsup:
