Central locking behaviour.
Jezclax
Hi all,
I unlocked my Auris using the key in the lock for the first time and I'm fairly certain that when i started driving the doors autolocked.
Am I imagining this?
Jez
the doors can be setup to auto lock i think its at about 10mph / 15mph when they lock
Don't think auto locking is available on the first generation Auris (2007-2012).
Maybe driver's door switch is not working and the ECU doesn't detect an open door, after 30 sec. it locks the car ...
Thanks for the replies.
It's fine when I open doors with the remote.
Will have another check on the weekend.
Jez
Finally remembered to look at this again.
If I unlock the drivers door with the key, only the drivers door is unlocked. Then as soon as I start the engine the door clunks to locked. I can press the button on the door to unlock/lock all the doors as normal.
Can anyone confirm that this is usual behavior for this model Auris? Seems pretty logical and repeatable.
Jez
 Different model but when I unlock the drivers door using the key the alarm goes off (maybe because its deadlocked?) and I have to start the engine to turn the alarm off. It only unlocks the drivers door and afterwards stays unlocked.
