Clutch judder
SAM LOVERS HER TOYOTAS
Good Evening,
as in the title, could anyone explain what Clutch Judder is exactly please, what the symptoms are?
And other possible issues one may experience in regards to a clutch in relation to T27's if applicable.
:blink:
Clutch judder is when the clutch pressure plate and friction plate don't drag over each other smoothly. Often caused by contamination of the friction material and causes a shaking of the vehicle when setting off.
What about engine mounts? Could a factor, but so are DMF or contamination.
