Rav4 2001 vvti 1998cc petrol
pukka63
Hi i have a problem - my Battery was dead past the point of recharging.  Bought a new one.
Now ive i have the Battery light on all the time when running the car. - Checked and cleaned all connections.
Tested - voltage on Battery 12.6V
              voltage on battery 14.25V  (eng running)
This to me say the alternator ok ??? So ive tried resetting the ECU by disconnecting the battery for 15-20mins and the fuses.
But the light is still on...... Has anyone got any ideas what i can try to fix this.
If there is a small diameter wire connected to the alternator, try cleaning the connection.
Its a DENSO 27060-2811alternator replacement parts now i believeis DAN951
Ive cleaned both connections 1- Battery feed
                                               2- 3pin connector   -( S IG L )-
No other connections in sight.
