P0125 Engine Management Light
SR71 Blackbird
Got this error a month ago. Ive changed the thermostat, coolant sensor and put new coolant. Also I have reset the engine management system. But the engine management light keeps coming back on.
Have you made sure there is no air-lock in the system. You are not losing any coolant?
Theres no coolant leaking and Ive bleed the system and the reserve tank is full
EXTRA INFORMATION
The last thing that I changed was the coolant sensor and I reset the engine management but still come on when I drove less than a mile. But after I drove the car for a good 20 miles it turned off but after a few days it came back and hasn't turned off since.
What tool do you use to read the code? Have you tried a genuine Toyota tester?
No Ive used that torque app to check it
