500AWHP project
salman2510
Hi there guys, well like the title says, building a 3S-GTE with at least 500 at the wheel. Here in Dhaka, Bangladesh, the Evos and STIs are running wild with 450-650awhp! Just wanna give most of them a run for their money!!
Please let me know if I need to add something or if I am doing something wrong. All your inputs are appreciated and thank you in advance.
It's a 5th Gen ST185 with 3rd Gen 3S-GTE (JDM Spec, 245hp). The MAF/AFM had to go!!
MOD LIST
1) Full Brian Crower stroker kit, 2.2 ( 2.26L - Includes 4340 billet crank, 93mm stroke, H-beam BC625+ rods (5.433 c-to-c), and custom forged pistons (87mm, 9.0:1 CR). ACL Race bearings available separately.)
2) Brain Crower 1mm OS Valve both Intake and Exhaust
3) Brain Crower Valve Spring with Titaniun retainers, Valve Keeper, Valve Guide
4) Brain Crower Stage2 Camshafts (254 degree) both intake and Exhaust with Fidanza Cam gears
5) Cosmetic Head Gasket (1.2mm)
6) Precision full turbo kit with 3" Downpipe
Turbocharger: 5830 58mm Billet ~560whp
Turbine Housing: .48 A/R (quicker spool)
Compressor: As Cast (standard)
Turbine Finish: Turbo Black Ceramic coated
Wastegate Dump: Rerouted (standard)
Wastegate: Silver 38mm MV-S
7) Mega Squirt PnP EMS
8) KO Racing Custom Turbo Manifold 3SGTE Gen3
9) ATS Racing Intake Manifold with 70mm Throttle Body Gen3
10) ATS Top Feed Fuel Rail Kit with 720cc injectors
11) MSD Ignition coil and KE-85 Plugwires
12) Blitz Nur Spec-R Exhaust System, straight 3" Pipe from downpipe, no cat
13) K&N Air Filter
14) Mishimoto Intercooler with 3" hard piping
15) Mishimoto Radiator with 2 Racing Fans (16" with 5 blades)
16) Mishimoto Oil Cooler
17) Mishimoto all Silicone Piping
18) Full SuperPro Polyurethane bushing (Top to bottom including engine mounts and diff mounts)
19) H&R Lowering Springs (HATE Coilovers), Koni shock absorbers
20) Whiteline strut bars (Front and rear), Ultra Racing fender bar, front and rear brace bar
21) OS Giken STR2C Clutch kit with flywheel (Torque Rating: 570 ft/lbs) but feels like stock
22) ARP Bolt for head and block
23) AEM Water/Methanol Injection Kit
24) Enkei RFP-1 Lightweight Rims (Gold color). 17x8, 5x100, 45 offset
25) 235/45/17Y Yokohama Advan Neova AD08R Tires (Need a lot of traction)
26) TRD Short shifter with M1 Abram Shift Knob (Black Satin with pattern)
27) GT-4 WRC Wing JDM Spec
28) Apexi AVC-R Boost Controller or GReedy Profec Boost Controller
29) Depo 60mm (Boost, Oil Pressure, Oil Temp, Water Temp)
30) Innovate AFR
31) Apexi RSM
32) HKS Turbo Timer Type-O
33) MOMO MOD. 07 STEERING WHEEL with hub
34) Carbon Fiber Hood
35) EBC Brake Disc & Yellow Stuff Pads & SS Brake Lines
