Greddy Profec B
Mister2
hi guys. i just got my boost controller and i dont really wanna take it anywhere to get it installed. for those who own one, was it difficult installing it? and any helpful tips would be welcomed! :thumbsup:
I took an hour to wire in my Apexi AVC-R - can't see the Greddy being that much different - a controller and solenoid?
mm.. the parts list include the controller, a valve unit, hoses, valve unit harness, power harness, fittings, filters, etc... so yeah.. basically same i guess.. so an hour huh. hmm.. did u have to use a soldering gun or iron?
wow, thats a whole lot of stuff I wouldnt hav a clue with...lol...pay a garage! safer. :D
What version of profec B is it?? older one or newer one?? I watched a friend install the older one in mine and it looked pretty damn easy (IF you have instructions) without instructions I wouldn't have been able to do it.
Cheers
KiwiMR2
Need a soldering iron ..
Whack in the Pressure sensor and the solenoid ..
Pop the harness through the grommet on the drivers side of the firewall .. run the wiring through to the ECU (may need to extend the loom) and tap it into the ECU ..
Then just plug it all together ..
i have the profec b ii.. wow bibbs.. u make it sound soo easy! i plan on mounting mine on the steering column..
It really is easy .. what form of boost control do you have now?
MBC :)
Cheers
KiwiMR2
:lol: yup... what kiwi said. thanx for all the tips and stuff. i just got done putting it in. its great!
