Best place to purchase an exhaust system 1998 Toyota Avensis
steve99990_4
Hi Guys
Anyone have any experience buying an exhaust system. Where the best place online to get one and how to find a quality one?
Moved to the Avensis club to generate some responses
I would go for EuroFlo as it closes resembles the original, with the exception that that the catalytic converter support was placed above instead of below, causing it to foul the under body. I had to grind off and bend the support to make the clearance needed. I still have the React catalytic converter (in the house in bag, and the Klarius middle/back box in the garden. The back box fits but is a little tight so needs careful fitting. They need to go, since I sold the car long ago.
Read my long posts for the detail -
Euro car parts was where I bought the Klarius mid/rear, React front pipe and catalytic converter section.
The Euro-Flo was from a local factor.
Hi Steve,
Not strictly answering your question...
My centre section and catalytic converter needed replacing at a similar time to Konrad's (cars of a similar age).
I had mine done at by the garage I use along with other MOT work. They use Blueprint ADL parts on the whole.
Referencing the part numbers the parts ordered and fitted looked to be Bosal.
Full details in Konrad's changing catalytic converter thread.
084.900.08
099863 cat converter
228625 middle silencer
were listed part numbers if that helps when searching.
They fit just fine so could be worth ringing around motor factors local to you.
