Wind noise Important - fixed
monkeydave
well i went into the dealers today with the wind noise problem and they checked the car over and couldn't see anything rubbing and they took me out in another car and it made the same noise at the back and also it was noisier at the front than my car
on the way home i decided to try Devon Aygos suggestion and i took the ariel off and the noise dissapeared completely
so dusty if your listening try removing the ariel before you remove the windscreen as you might be lucky too and better than removing the windscreen
and i thought the noise was from the bottom left rear and i had my camera all over the back and it didnt pick any noise from the roof, just goes to show
so thanks very much devon aygo, you made my day and fordulike who suggested removing the ariel in the past thanks also
