EPB fault 'Check Parking Brake System' returns.
Konrad C
1 hour ago, Konrad C said:
Techstream has to loaded on to a laptop, though some came preloaded on laptops for professional use. Same goes for the Delphi software. Both came with cable - mini VCI USB to OBD2 for the Techstream, USB to OBD2 with Bluetooth for the Delphi. I also have a stand alone Launch which can do most things, but not a patch on Techstream.
i loaded techstream on to a spare ssd i got iput windows on it then loaded techstream on it as my laptop i can change the ssd easy on here just 2 screws on it
12 hours ago, 2009joe said:
This site can’t be reached
www.icarsoft.com’s server IP address could not be found.
not coming up for me
Works on my Laptop.
John
10 hours ago, JARC1 said:
Works on my Laptop.
John
Just tried again and the link is still working.
John
Hey guys, I’ve made quick vid regarding epb. Last summer I have replaced the actuator and eventually I made the error message gone via techstream. It may be not permanent because it reoccurred when I had check engine light after I have forgotten to connect injector but I have repeated the steps and it worked again. So I’m leaving the link here
Was problem with failing epb resolved in later models of avensis ? Any year to avoid ?
class job and video by chance u got that techstream from eBay they give you a code when you buy it to work on your laptop. when i got mine i bought a cheap seprate ssd for putting techstream on and i just take out the sdd and put it into my laptop and have it from there incase have to reinstall windows on my laptop incase something goes wrong
  • 5 months later...
On 12/29/2022 at 10:57 PM, 2009joe said:
class job and video by chance u got that techstream from ebay they give you a code when you buy it to work on your laptop. when i got mine i bought a cheap seprate ssd for putting techstream on and i just take out the sdd and put it into my laptop and have it from there incase have to reinstall windows on my laptop incase something goes wrong
Sorry for late reply. Yes, I got the techstream from eBay but it was pain in the a to install so I have browsed forums and one have had guys sending you the activation codes. I don't know if that works till this day but eventually I did manage to make it work on my win10 laptop. What I'm using in the vid is dualboot laptop with second partition with dedicated win xp. Handy to have if youre about to go for a journey. After making this vid, error didn't showed up. My avensis is being replaced with other car. Within 4 years I did 50k miles with it and I have great sentiment. Especially bonding experience was breaking seized bolt in the engine block that held the injector clamp :).
On 6/27/2023 at 12:51 PM, Ananiash said:
Sorry for late reply. Yes, I got the techstream from ebay but it was pain in the a to install so I have browsed forums and one have had guys sending you the activation codes. I don't know if that works till this day but eventually I did manage to make it work on my win10 laptop. What I'm using in the vid is dualboot laptop with second partition with dedicated win xp. Handy to have if youre about to go for a journey. After making this vid, error didn't showed up. My avensis is being replaced with other car. Within 4 years I did 50k miles with it and I have great sentiment. Especially bonding experience was breaking seized bolt in the engine block that held the injector clamp :).
You can buy the cable off eBay and run the software off a virtual machine running XP; Oracle Virtual Box works fine for me. This vid also has prebuilt images of XP to easily load into the VM
Was the EPB problem resolved in later models, or should one stick with pre EPB Avensis models?
It is stated by Surrey Electronics that Toyota stated in April 2014 that:
"We are confident that the known moisture issue on the Avensis electronic parking brake system has been acknowledged and there has been a change in design of this part which has improved the seals. The design of the main box has also been improved."
  • Haha 1
  • 11 months later...
Just bought an Avensis from auction and within 15 minutes of driving it the Check Parking Brake System warning came on. Came across this thread and low and behold the wire to the sensor was dangling in the breeze along with the clip on the gearbox. Plugged back in and all is good. Upside it looks like it may have had a new clutch and the mechanics didn't re-attach the plug. Someone must have turned the warning off before it was auctioned. Would of been easier to fix it!!
Thanks to the guys above for the advice.
