Handbrake hub assembly
Whatif
Hi, I had to dismantle the handbrake shoe assembly on my 05 Avensis D4D to put in a new wheel stud. I made the stupid mistake of not taking a picture of it beforehand. Turns out it's a lot harder to put back together than take apart. Does anyone have a diagram or photo of it by any chance? I could look at the one on the other side, but the brake caliper bolts are a bugger to get off.
I'm wondering if the spring for the shoe strut got lost when I took it apart - either that or it didn't have one in the first place, because I can't see it anywhere.
Any responses?
I did a quick hunt and found these images.
AVENSIS |  REAR DISC BRAKE CALIPER DUST COVER
AVENSIS |  PARKING BRAKE CABLE
graphic
I no it's a bit naughty, but it's the best I can do.
Thanks Konrad, I'll see if I can use these as a guide to reassembling it.
Ignore the last diagram, as it for the T22 Mk1 Avensis. I only realised this after looking at the Haynes manual. The other diagrams showing part numbers, are for the T25 Mk2,.
Yes, this diagram of yours is the one that matches my Mark 2:
