Alloy wheels
Guitarman69
Hi, so I just got an 02 plate celica, it had 18" multifit alloys on it which were too big, I've purchased a set of original alloys only thing confusing me is what nuts should be on them, it was tapered nuts on the multifit, can anyone tell me should I use flat or tapered on new wheels, pic below, thanks in advance.
Check down the hole where the wheel nut goes, if the bottom has tapered edges then it needs tapered nuts.
It is imperative you use the OE flat type on these wheels. It would be dangerous to use the tapered type.
Thanks for your help guys, I thought something wasn't right when I was putting nuts on! But wanted to double check before I go buy them!
