starting problem?
kank
first time here so not entirely sure if im in the right place.
98 avensis refuses to start on the key but bump starts relativley easy,then starts ok on the key when warm.
checked resistance on crank sensor,coils,temp sensors and injectors-all ok.battery voltage good and fuel is getting through ok.
not sure if its plugs but it runs ok once started. a strange one,any ideas??
