Jap engine into french car - crank rota change over?
jamie1011
Hi everyone.
As the title says im halfway through an engine swap and noticed the cam sensor plug is different - i read a thred on here that said all i have to do is tap the pins out a little on the cam to accept the new cam sensor and then change the crank rota behind the cam chain cover for the crankshaft sensor.
I have stripped it down and they are slightly different but if i change them would it effect the cars ignition timing at all???
Bit confused here? Any help greatly appriciated.
