Rear tail/brake light
Tina1217
Hi, the rear light on my aygo has gone, ive changed the bulb but that hasn't worked, could it be the fuse, if so where are they?
I could be wrong, but I would have thought that a blown fuse would knock both rear lights out. As I say, I'm not sure.
Take the bulb back out and take a look inside the holder to check for rust on the contacts, which could prevent the power getting to the bulb.
Is the same side front light out? Which could indicate a fuse. Some cars were fused side to side. Go along to a garage and ask for them to have a look.
Thanks for that I'll give it a try.
Hi, all other lights are working including indicator and reversing light on same side.
