Check 4x4 system
danicalifornia2222
After a few miles driving I get the same warning flashing up on my dash check 4x4 system. Any ideas what's going on?
thabks in advance
If you want to penetrate the issue without going to a dealer, I think you will need to read the fault code(s).  This requires a laptop and suitable cable, plus software.  The best software is the real McCoy, Toyota Techstream.  I bought this one and no worries.
Thanks Ian I might check if any one local has it first!!
  • 3 years later...
Check 4x4 system is constantly showing on the display on my 2006 rav4.wat is the problem
Mine came on the other day, sometimes this can be serious and most times (in my opinion, it's just the car throwing a wobbly and having a bad day).
I cleared mine with a normal OBD reader and it's never came on again.  Obviously it's very wise, if you clear it and it keeps coming on, then you do probably have a issue and it should be looked at.
  • 1 year later...
Hello, I had this problem with RAV4 2008 classic fuel (not gasoil)
the Toyota dealer proposed to change the computer,
I had change my rear tyres one year ago, someone on some forum mentioned, it is needed to change all tyres
so this year i change the 2 front ones, and the alert disappear.
This is it !
