Gen 4 Tyre Pressures.
Chris Dance
With the gen 4 I found that checking the tyre pressures was awkward using my existing RAC tyre pressure gauge due to the wheel trims. I have now solved this problem by purchasing a new tyre pressure gauge from Amazon. This gauge is robust and strong and very flexible. It is also said to be very accurate. I recommend it. Here are the details.
TireTek Flexi-Pro Tyre Pressure Gauge, Heavy Duty Car & Motorbike - 60 PSI
