Click at Full Lock
YarisHybrid2016
It seems to be when the weather is warmer, when turning full lock to the left (I think) there is a click from the steering column, and it can be felt in the steering itself. Full lock is attained without problems, and the click doesn't seem to occur when returning to center.
Is this a known issue, and should I get it investigated?
The only way I can describe the click is like the indicator when it latches ready to switch off (e.g. indicate left, then steer left), only at full lock and with the indicator off.
