Rav 4.3 2.2 D4D EGR Valve Compatibilty
ASeyc
Hi
Does anyone know if an EGR Valve motor from an Avensis (p/n 25620-0R020) is interchangeable with my RAV4 EGR Motor (p/n 25620-26091)?  I have a problem with the motor itself and need just that part however I cannot find any reasonable rav4 ones on the net.  Visually they look the same.
25620-0R020 only lists on 2.0 d engines not 2.2,
part numbers :
25620-0R010 replaced by 25620-0R011 replaced by 25620-0R012 does cross models
also
25620-26090 replaced by 25620-26091 replaced by 25620-26092 are available for Rav
if you can try and get the latest numbers as these are improved modified parts
Will try to find 26092 but it is proving to be very difficult
