Rear upper control arm bush dust covers
catseye27
Hi.  Looking at replacing my rear disc's, pads and shoes.  Noticed the dust covers for the bush on the upper rear control arms out of position, spring should hold rubber in V groove.  Only way i can see of replacing them into their correct place is by removing the control arm. (strong spring holds rubber dust cover in place)  Released the bolt but looks like a bush goes right through the whole assembly.  Anyone know if this bush is easy to remove?
OK. Answered my own question. No bush through complete assembly.  Jammy bar and out popped the upper arm. Dust covers now back in correct place after a cleanup and added grease.
