Rear power socket
MuchMorepower
Hi all, does anyone know an easy was to make the power shocker in the boot permanently live?  I have taken the feed for my tow bar electric box from here but it only works when turned on so no hazards etc.
cheers
Just read that back, damn auto correct 😡 Should be the power socket 👍🏻
I think you would need to re-wire it from the engine compartment, and, if you're doing that, you would be best taking a separately fused supply straight from the Battery to the box.
Then, when not towing, just remove the fuse, and the original integrity of the system is not compromised.
