Boot Open Warning issue
Bart287
Hi
My wife's 2010 Avensis Tourer has developed the same issue Neil1508 posted in May:
"Please can anyone point me in the direction of how to fix a boot (tailgate) warning that keeps pinging on?
The boot is definitely shut (locked even) but the warning 'pings' and shows on the dashboard display pretty much every time I turn a corner or go over a bump. It's driving me mad!
Any pointers greatly appreciated"
Can anybody provide any info diagrams? regarding location of connectors/switches etc so I could perhaps look at these before heading to the garage?
Thanking you all in advance
Hi
FYI - I sourced & replaced the Boot lid Trunk lock Mechanism with a second hand unit about 10 days ago and this has solved the problem, up until now anyway.
It was literally a 5 minute job. Loosen interior panel and remove 3 x #10 bolts and the wire connector unit came very easily.
Unit was £25 + p&p
Maybe useful info for anybody else who comes across this problem.
Cheers
On 2017-7-2 at 6:35 PM, Bart287 said:
Hi
Unit was £25 + p&p
Cheers
Thanks for the info. I suspected the door switch had been integrated into the lock. I would like know how it was put together, to see if there is a way of repairing it. Hopefully it is one off fault.
  • 7 years later...
Hi I have the same problem with the with my Toyota 2011. I'll try to fix it and find a solution how. If you gues wish to be updated how it goes just tell me
