Power steering gone !
fellrunner
Hello all,
Toyota Rav4 (2002) Petrol
Just driving home when sound similar wheel picking a stone up ratteling around,
followed by Battery light on and loss of power steering also temp gague hit max
before settling back down.
Anyone any thoughts on what problem could be.?
Many thanks.
David.
Snapped aux belt?
On 6/24/2017 at 0:19 PM, alan333 said:
Snapped aux belt?
I suspect the same, a snapped belt. Also check the crank pulley for side play, as well as the other pulleys. The crank pulley tends to have rubber filling, between the inner and outer solid metal sections, as the pulley acts as vibration damper. When this pulley delaminates, the belt can be damaged too. Aged of the belt is another factor.
