White smoke on start-up.Pcv valve guess
Zoki
Hi.
New in forum
So i have auris 2.0 d4d 2008.
Recently start white smoke on first start.
I was looking around and all arrows looking on Pcv valve.
Try to find and cleaned or change but no result.
Anyone who know were i'ts located possible with some pictures?
Thanks in advance
Can't speak for Toyotas, but white smoke on a diesel usually means unburned fuel. It might be just that the air feed is compromised (mucky filter, air leak around the intercooler etc), but when it happened on my Ford Focus it signified a failing fuel injector. :sad:
Is the car hard to start, and does it run normally once it's up and away? How's your coolant level in the reservoir tank?
Coolant level Ok.
On colder moornings start is slightly longer after start everything look good.
The car is good on fuel,accelaration,speed.
Any ideas how to check injectors
Or any advise what could else be
