kblevis
kblevis
Greetings,fellow Members.
I now have a 2013 Toyota RAV4 D 4D and I would like to know how to increase the brightness of the Dashboard lights as during the day,the little blue readout at the bottom of the speedo is very hard to see,also the speedo itself.There is no dimmer switch on the right of the steering wheel so is there another way to do the adjustment? Many thanks for any help and/or advice you can give me,kblevis.
The button on the multi information display will switch between odometer, trip meters, and instrument lighting control.
With the sidelights on, press the button until the instrument lighting control is displayed (a series of one to four blocks of varying height). Press and hold the button and the brightness of the lighting will change - once the required level of lighting is right for you release the button.
Greetings,FROSTYBALLS.
Many thanks for your rapid answer.Just the job,now I can see what is going on.Thanks again,kind regards,kblevis.:biggrin::laugh:
