Trouble codes 44 and 55?
Pyroman
Hello!
Sry my bad english, but i hope you understand my question ;)
I have T25 Avensis with D4-D 85 Kw engine. 2004 year.
I trying to get troble codes in this way:
And get codes, like 44 and 55. Three times checked and controlled. All times same codes.
But problem is, cant find on the internet, what this codes meaning?
I found a lot codes for OBD scanner, but this way ....nothing!
Maybe someone can help and explain to me about this codes?
Thanks!
Best get it on to a diagnostic tool..you could take the Battery terminal off for 10-15mins then put back on to see if it clears.but this could only masked what's actually happened.
I agree with Frank. The self diagnostic list I have only goes up to code 41. This is before VSC. You need a diagnostic reader that can read ABS/TRC/VSC plus SRS codes, not just EML codes! Or go to someone with the right equipment. I own a home mechanic reader that covers most general systems.  Toyota Techstream is another way.
