2011 toyota Auris 1.6
chuckwnels
The mutilmode transimission stoke in (N) i need some advise about this plz respond are email me at chuckwnels@gmail.com are whats app me at 18763760442
Duplicate thread deleted.
Responses will be via the forum - we discourage members using their own e-mail addresses, etc on an open forum.
Manual automated transmission. Worst transmission to have in any brand of car. I searched the 'net and found these from this very forum -
and from Honest John - https://www.honestjohn.co.uk/forum/post/index.htm?t=97184
Not transmission is perfect, but multi-mode seems to be the worst because of how complex it is to fix and set up. You need to see a transmission specialist, somebody exeroienced with Toyota multi-mode in your country.
The specialist says he need a program to load back in the computer so the vehcile can drive now i'm not sure what's that about........ I'm not understand that part
I only have read about the multimode transmission and what is function is. Basically the car has a normal clutch and gearbox, and a computer controlled actuator controls the clutch and gear changes. Here are some info links -
http://pmmonline.co.uk/technical/the-toyota-multi-mode-transmission-design-and-function/
http://www.sinspeed.co.uk/toyota-mmt-clutch-actuator-gear-actuator-repairs/
If the mechanic told you he needs a program to fix the transmission, Techstream is the only one I can think of. I don't really know that much, but the info I linked to you should help.
