Got an issue with split front anti roll bar bushes on the wife's 07 Aygo, I've purchased replacement bushes from Euro car parts
Anyone done the job previously, are the bushes easy to get at, anything to watch for, how long to do the job.
Thanks in anticipation.
i haven't replaced the bushes on an aygo but i have done them on other cars
before fitting the split bush put some washing up liquid on the bush on the
inside and outside before fitting to the bar as things will slide into place when
fitting the U shaped bush clamp.
Eygo,
Many thanks for the reply, was gonna use red rubber grease ( I read it somewhere).any idea where the bushes are or is it gonna be obvious ( I'm replacing discs and pads at the same time.......)
Thanks again,
B..
here is an image of an anti roll bar with the bushes in place
once the car is up on stands wih the wheels off remove the drop links first
this will remove any tension in the anti roll bar, they fasten to the end of the
roll bar and to the lower suspenion ,undo the retaining bracket and unclip
the anti roll bar bush then refit in reverse.
Mark,
Good man, exactly what I needed!
Regards,
B
