kblevis
kblevis
Greetings,Fellow Members.
I now have a Toyota 2013 RAV4 diesel and I'd appreciate your help in trying to send a contact number to the Broadband from my Alcatel PIXI 4 3G phone.Whenever I try,it is refused.If it helps,the phone cannot "see" the car bluetooth. It's a bit of a pain and I only want about eight phone numbers in the car memory.Hopefully,there is an answer to this and one of you wizards will find it for me.Regards to you all and thanks for any help,kblevis.:mellow:
Hi & welcome to TOC :smile:
Can you confirm that it is Touch  rather than Touch 2?
Have you tried pairing?
Greetings,Heidfirst.
Thank you for your answer. It turns out that the bluetooth would not read the SD  chip in the phone,so I changed it so that It read from the phone's internal memory.Worked a treat.All numbers now installed and all is well. Thanks again as I will never know it all.Kind regards,kblevis.
