Heaters not blowing hot air in cabin 2006 avensis
avensisd4d786
Hi guys its been a while today's question involves a 2006 t2 manual heating system.
Both pipes going into engine are hot.
No coolant loss
Just changed the heater control panel still the same.
Please can someone advise
Hi I. Not sure if this applies to you but there is a way to check heater via self diagnostics - http://www.cardiagnostics.be/-now/Self Diagnose Toyota Corolla ECC-panel.htm
This diagnostics works on my Mk3. The T2 may not have 'auto' so not sure if self diagnostics is supported. The airflow between hot and cold is directed by flaps. Let's hope that works.
Can someone advise how to locate 87106h 87106-02030 its a air mixer.
Found it. Its on drivers side near clutch pedal behind carpet footrest needs to removed to gain access. I have manually move the flap to hot so i now have hot air. Will replace motor when i get chance.
Well done 'I'. At least you found the problem. The description for the motors used, are servo dampers. Can before confusing. That means your heater/air-con is only missing a few parts to make it full climate control.
