Main beam dash light
MuchMorepower
Hi all
the blue main beam light on my 2003 RAV has stopped working, 'I'll put a new bulb in" I thought so took the dash out to find no bulbs that I could see, I took the glass off and the back off but not a bulb in sight.
Help please anyone😱
Graham
it's probably an SMD (surface mounted device) bulb - a small LED soldered direct to the board. if your own soldering skills aren't up to it you can probably send the whole thing away to somewhere to get it done rather than replace the whole dash.
