Indicators "beeping"
Mikeyjd
Recently our Rav 4 has started to beep when indicating right and also when the hazard lights are on. This does not happen when turning left. The sound seems to be coming from the rear of the car in the luggage area. I assume this is the signal that some cars make when a trailer is attached to confirm that the trailer lights are flashing. I do not use a trailer, so I'm guessing that a wire is loose or earthing or similar.
Anyone know exactly where the unit is and is it easy to just disconnect it? Or if they think it could be something else.
If you have a towbar fitted, the wiring is usually done on the passenger side behind the rear quarter panel.
Thanks, will take a look on the weekend.
