T25 1AD-FTV loss of power
jani_tool
Any help? When I start my car, and drive about 5 minutes, car goes some limp mode. After that it won't accelerate properly. Car won't give any DTC's. When I stop the car and shut it down, then restart, it will work fine again another 5 minutes.
  • 2 months later...
New information to this issue. When I'm driving and pumping gas pedal continuously, problem doesn't occur. But when I stop pumping, problem comes back after 1 minutes.
Have you connected a reader that will capture the manufacturer specific codes rather than just generic ones? You may find that helps if not.
I had an avensis t3x and had similar problems ,Mine was a D4D and I cleaned the filter in theDiesel tank accessed under the back seat wax like gunk removed and problem gone.
I've used Techstream to read codes. None occured.
I have to try that solution, I get back after that.
thankyou.must see what I can get.
I cleaned tank filter, no luck. Filter was very dirty anyway. I think that problem might be an alternator. I doubt that charging voltage is too high. If I start car with empty Battery, problem won't occur. Can anyone say how much charging voltage should be when engine is running?
I had a similar problem with my old focus. I had to turn car off, and then limp mode would stop. RAC guy said it was temperature sensor. I did fix it by squeezing the connector to the sensor.
Was that intake air temperature sensor?
5 hours ago, jani_tool said:
Was that intake air temperature sensor?l
No, the sensor was deep inside the engine, measured engine temperature. Always check sensor connections first. Though I could not see it I could feel it.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
