boot tray removal
busterb
Have acquired a brilliant 08 rav4 but need to make space in the boot for a full size spare wheel as not a lover of blow-up/get you home spares - any suggestions as to how to remove the moulded insert in the boot appreciated
thanks
Is it not fastened in with those sort of large plastic push rivets.
I have a 07 rav4 and I removed plastic tray by removing plastic grommets . could only remove tray at rear, took screws out of front tray but still would not come out.
also space not big enough for spare .
I bought a spacesaver and leave it loose on top.
Hi Buster, I saw a Rav that was imported (Which had a V6 engine which is not made for the English market) well it had a full sized spare with a different boot floor, deeper for the spare and had a raised hinged cover so things like shopping could be put in the boot area. My self I just bought a full sized wheel and tyre and lay it flat in the boot horizontally, I know others that store them vertically behind the rear seat and the cross bar where the curtain comes out of. Mike.
