Common parts between models
gezhenry
Do Toyota use any common parts between different models from the same era does anyone know this?
For example mine is a 2006 celica vvti and I assume any other 1.8 vvti has the same engine parts but I just wondered if I can get any other type of  secondhand parts from the more common avensis or corolla from similar years?
Obviously there will be some commonality between models of the same era. However, as regards, for example, engines, the state of tune may well be different, or different versions of the same engine.
