Extreme power loss
frankie406
I have just got the gearbox replaced yesterday and the car has no power what Could the cause of this?
What did you exactly replace and more info on car?
Sendt fra min SM-G920F med Tapatalk
The gearbox box as the 5th gear was popping out.its a 2006 2.0d4d pre-face lift avensis. Literally no power it feels like a non-turbo diesel.
If the car was okay before repair, then there must be are vacuum hose or something like that, there is not attached
Another thing that I have noticed is when I brake the brake light ( ! ) comes on the dash could tha be linked in some way?
Who did the gearbox change, a known, good garage or a Mr Clutch type place?
Sounds like a vacuum hose is disconnected or broken.
Craig.
There are likely something wrong with the connection to or the vacuum system. Tjek it up
Cheers guys found it.was a small hose under the steel turbo pipe.
