03 avensis d4d pipe
Barrie666
Hi I got a pipe that has split need to replace it but what is the pipe called and there is oil going through it into the air pipe and into the turbo. Is it supposed to be there thanks
It's the "pcv"breather pipe.you will get oil being sucked in by the turbo.the oil vapour and the egr soot meets together and leaves a sticky mess give the egr valve,throttle body a good clean..you can get a piece of hose that's the same diameter that is suitable for oil..I made a oil catch can to help stop the oil vapour.
